What are all the FME Server config files where the hostname is listed?
  • September 20, 2017
  • 45 views
fmelizard
Forum|alt.badge.img+22
What are all the files that specify the FME Server hostname, that can't be accessed from the FME Server Web UI or backend database?
Best answer by rylanatsafe
With great knowledge, comes great responsibility. Edit these files at your own risk!
This information has been gathered from an FME Server 2017.1 installation.
<FMEServer_Install>\\Clients\\FMEServerConsole\\FMEServerConsoleConfig.txt <FMEServer_Install>\\Clients\\utilities\\addCleanupTasks.bat <FMEServer_Install>\\Clients\\utilities\\addPublishers.bat <FMEServer_Install>\\Clients\\utilities\\addServices.bat <FMEServer_Install>\\Clients\\utilities\\addSubscribers.bat <FMEServer_Install>\\Clients\\utilities\\configureDemoWorkspaces.bat <FMEServer_Install>\\Clients\\utilities\\serviceWorkspaceDefs.xml <FMEServer_Install>\\Clients\\utilities\\serviceWorkspaceDefs_old.xml
<FMEServer_Install>\\Server\\fmeCommonConfig.txt
<FMEServer_Install>\\Server\\fmeServerConfig.txt
<FMEServer_Install>\\Server\\fmeWebSocketConfig.txt <FMEServer_Install>\\Server\\processMonitorConfigCore.txt
<FMEServer_Install>\\Server\\processMonitorConfigEngines.txt
And,... these files reference "localhost" in some (or most) FME Server installations.
<FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmeaws\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmedatadownload\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmedatastreaming\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmedataupload\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmejobsubmitter\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmekmllink\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmenotification\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmeoauth\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmerest\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmeserver\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmetoken\\WEB-INF\\conf\\propertiesFile.properties
rylanatsafe
Forum|alt.badge.img+14
