I have put together a FME 2014 server workbench (as attached) that allows the user to select an input shape file and output a series of shape and dwg files that contain data from an SDE database that intersect the input shape area. The process to produce shape files has been in place for some time but I’m now being asked to output the same data in dwg format. I’ve been told by others that the dwg writer will not always create the data properly (at times outputting data from one attribute into another, or dropping attributes, or adding others erroneously). I’ve not seen this myself but I need to prove that the data from the output shapes match that in the single final dwg. In my case the output file is defined by a schema mapper which renames the shape files and places them in a selected folder so it’s not as simple as checking a simple list of attributes. The output for any given shape file output will be placed on a corresponding layer in the dwg. Can you prescribe a method by which I could verify that the shape file data matches the dwg data?
verify shape and dwg match
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
