Validate a JSON file against a specified schema
  • Apr 15, 2023 10:27 AM UTC
  • 5 replies
  • 463 views
JSON2ValidateSchemaI have a schema JSON file that I want to use to validate various JSON files. What transformers can I use to perform this functionality? JSON Validator only validates syntax and not schema so what's the alternative for this?
I have added pictures of the sample JSON schema and also the JSON file that needs to be validated against that schema.
ctredinnick
Forum|alt.badge.img+22
  • Apr 15, 2023 12:30 PM UTC
A basic way could be to use a JsonExtractor to pick out certain attributes in the json, AttributeValidator to see if they have values. That won't work though if you're expecting there to be empty values.
A more complete approach could be a JsonFlattener with a SchemaScanner perhaps.
hkingsbury
Forum|alt.badge.img+73
  • Apr 16, 2023 8:19 PM UTC
An approach along similar lines could be to read in the JSON Schema File with a FeatureReader set to only read schema, then concat the list down to a single attribute. Then read your other JSON files in (getting the schema as well) and repeat the same with the schema and check that the two result schemas (from your JSON Schema File and JSON Data) are the same
  • Apr 16, 2023 9:05 PM UTC
Thanks for your response. How do I concat the list (also which list to be concatenated?) ? I'm getting fme_feature_type_name,format_short_name. long_name & schema_handling as output of the schema of Feature reader. I've shared screenshots of the workbench. Please have a look and suggest.IMG-9555IMG-9554IMG-9553IMG-9552
  • Apr 16, 2023 9:21 PM UTC
Thanks for the response @ctredinnick​ . I have shared a sample schema and JSON file. I need to validate the file against the schema. Please have a look and suggest the best possible approach.
ctredinnick
  • Jan 7, 2026 2:48 AM UTC
JSON schema validation is now supported since FME 2025.1, on the JSONValidator. It validates your data against a json schema file.
If you want to use the JSONValidator to validate json which is posted to your workspace in a DataVirtualization workflow, read the data validation’s source open API json file, then you need to extract out:  json["components"]["schemas"][*]  - that’s the part of the json with the format the schema validation needs. Test for the schema name if you have more than one. Unfortunately have to write the schema to a file for the JSONValidator to validate the data against, but it’s only an extra transformer to do that.
It’ll identify missing/required items, data types, anything else which can be set in a json schema.
