Using Tester transformer with 'Right Value' coming from another transformer
  • Jan 16, 2017 2:04 PM UTC
  • 94 views
Hello,
I have a set of lines, with the attribute 'name' coming from a first dataset and another line with the attribute 'linked_line_name' coming from a second dataset.
The second dataset only contains one line.
I'd like to select the line from the first dataset where 'name' equals 'linked_line_name'.
So far I've tried using the Tester transformer but can't seem to make it work as I would like to.
I created and joined a sample workspace to illustrate my problem a bit more:
The first dataset contains 4 lines, the second just 1.
I want to select the second line 'def' from the first dataset as its 'name' attribute equals 'linked_line_name' from the second dataset.
I understand why the parameters I've entered for the Tester transformer won't work but I can't figure out a way to achieve what I want. Any idea?
Thanks a lot!
Elise
Best answer by ebygomm
You can use a featuremerger to perform this test. Send the lines to the requestor, with the single line to the supplier merging on name:linked_line_name and merging attributes only. Only lines which match will come out the merged port
Forum|alt.badge.img+54
  • Jan 16, 2017 2:09 PM UTC
itay
Forum|alt.badge.img+19
  • Jan 16, 2017 2:20 PM UTC
As pointed out the FeatureMerger is one way to go, optonally if you prefer a more SQL apporach the InlineQuerier is another option.
The reason the tester doesnt work is because the features do not get joined (merged) and therefore the test cannot be carried out...
  • Jan 16, 2017 2:21 PM UTC
Thank you so much, this is exactly what I was looking for, this community seems amazing!
  • Jan 16, 2017 2:38 PM UTC
Works perfectly too, thank you! I didn't know about this transformer, seems like I'm going to use it a lot!
Which option would you say is better?
In this article it is mentionned that the InlineQuerier can be used as a replacement for multiple FeatureMergers. What about a single FeatureMerger?
