Unable to Connect to BigQuery
rzel24
Forum|alt.badge.img+7
Hello,
I was wondering if someone here could give some guidance to a problem we are experiencing.
We our trying to connect FME to BigQuery but regardless if it is the reader or writer we are unable to connect using Web Connection.
For the Web Connection settings we use or own accounts which have access to BigQuery. In fact when we connect directly to BigQuery we are able to see the project, datasets and tables and we are able to run queries on them.
But when trying to establish the connection from FME using Web Connection we get the following error:
BigQuery Connection Error
Any help on how to solve the issue or to even find out what exactly is wrong would be appreciated.
Thanks in advance.
RZ.-
Best answer by rzel24
Unfortunately the Web Connection does not seems to work in our case, so we had to set up a Service Account with the access needed.
The following were the permissions given to the account:
bigquery.jobs.create
bigquery.jobs.list
bigquery.jobs.listAll
bigquery.tables.create
bigquery.tables.update
bigquery.tables.updateData
Additionally we had to add the BQ Data Viewer role to the account.
We had to set up a new system environment variable (in both Form and Flow):
GOOGLE_APPLICATION_CREDENTIALS with value “Path_to_SA_Key_File”
After that we are now able to connect to BigQuery from FME Form and FME Flow.
Regards,
RZ.-
emma.at.safe
Forum|alt.badge.img+8
Hi @rzel24,
Thank you for your question! We also have received your support ticket. Here’s a summary of our recommendations:
  • Ensure the Google BigQuery FME package is updated to the latest released version (1.1.5). You can check the package version installed in Workbench using Tools > FME Options > Packages. Delete any existing Big Query connections and recreate it. This ensures the web connection is using the latest web service definition.
  • If the error still persists after these, we would recommend to create and use their own OAuth2.0 app for Big Query, as the default Big Query Web Service definition that is provided by Safe Software is not recommended for production use. The preferred option would be to create your own Google App (client ID/secret) to use within FME.
Emma
rzel24
  • October 22, 2024
bigquery.jobs.list
Regards,
RZ.-
