Trouble with ChartGenerator (Colour and Labels)
  • August 31, 2022
  • 23 views
stefan_kutac
I'm working with the ChartGenerator Transformer to create a bar chart and have two questions:
1) How can I change the bar colour so each bar is a different color? I did find a post to change the RGB to (0-1,0-1,0-1), but my entry is still pink, so I can't use that.
image2) How can I add a label showing the number of items at the top of each bar? The PowerPiontStyler has an option for "Label Data", but I don't see one within the ChartGenerator. Currently, my table is shown like this:
imageThanks in advance!
kailinatsafe
Forum|alt.badge.img+21
Hello @stefan_kutac​, thanks for posting!
If we take a look at the ChartGenerator documentation, and navigate to Colour parameter under Bar section, we see that color values need to be written like "0,0,1". For example, if I wanted my bars to be red I would enter: 1,0,0
For styling individual bars with unique colours, we can assign unique colour values per feature to the fme_color attribute, and assign this attribute in our ChartGenerator for Color like this:
This will output a bar chart with different coloured bars.
There is actually a parameter section for this in the ChartGenerator! If you open the ChartGenerator parameters > Axes > you should see X / Y Axis Label fields, which sets the label along the X/Y axis.
Let me know if you get stuck somewhere, happy to help! Kailin.
