Transformers to create raster with dimension higher than the reference image and addition of text box with fixed position
  • Mar 15, 2022 5:06 PM UTC
  • 89 views
Hello!
I need to open a raster and use it as a reference to create a larger one (a few inches bigger on the height of the initial image).
This procedure must be done for a set of images of varying sizes and not georeferenced.
Later on combining the two files, the original and the other that was created (I thought use the RasterMosaicker), I would have an additional blank area at the bottom of the image where I could add a text box.
I'm having trouble with:
- creating larger images that have as reference a set of images of varying sizes
- adding the text box with message in the fixed position (the bottom border that were added in each resulting image).
Does anyone know any transformer or transformer set to solve this problem?
Thanks for help!
danilo_fme
Forum|alt.badge.img+58
  • Mar 15, 2022 6:00 PM UTC
Olá @thaisafaria​
Please, could you share the Workspace template?
Obrigado!
Danilo
Olá Danilo!
Eu evoluí pouco no modelo, mas segue.
Obrigada!
danilo_fme
  • Mar 15, 2022 7:11 PM UTC
Olá Danilo!
Obrigada!
Obrigado.
Vou dar uma olhada e te respondo.
Anota o meu email. danilo@solutial.com.br
