TestFilter
  • July 12, 2013
  • 83 views
farfar
Forum|alt.badge.img+12
I've a feature that contains 100 regions and i'd like to get shp file writer for each region. I use TestFilter transformer to do it but i must set TestCondition 100 times (If @Value(regionId)=1 else if If @Value(regionId)=2 else if ....).
Is there other solution ?
Thanks an advance.
Farfar
  • July 12, 2013
how about using a dataset fanout on the value of RegionID?
http://docs.safe.com/fme/html/FME_Workbench/Default.htm#Setting_Dataset_Fanout_Properties.htm
David
  • July 12, 2013
If you want to separate output directories based on the region, try setting the Dataset Fanout Properties as David suggested. But if you want to separate output files in a single directory, take a look at the Feature Type Fanout Properties.
Takashi
farfar
  • July 12, 2013
Yes, it works.
Thanks
