Suppressing the fme.exe command window
I am doing a batch conversion of several thousand files using a powershell script. Unfortunately I have to do this on the same computer that I do other work, and the fme.exe command window constantly popping up is a bit of a pain. Is there any way to suppress the window popping up for every file converts?
