String concatenator not writing correct string
bubblebeb
I am using a string concatenator to
write batch files for me.
I am entering a windows path in the string concatenator (see
below).
%SendKeys% "E:\FME\Development Work\Timesheet
Analysis\Output\@Value(HomeTeamFP)\@Value(Name) @Value(DateFrom) to @Value(DateTo){ENTER}"
But the string it writes out is
%SendKeys"E:\FME\Development Work\Timesheet
Analysis/Output\RUR370\Amy Hutsby 2018-01-01 to 2018-01-31{ENTER}"
I.e. it changes to ...Analysis\Output... to
...Analysis/Output...
This then leads the batchfile to fail to work.
It has happened several times and I dont know what is
causing it or how to fix it.
Any ideas from anyone?
Thanks
davideagle
Forum|alt.badge.img+21
  • February 9, 2018
Hi Seb, An absolute hack is to follow it with a StringReplacer that swaps / to \\, it's a hack that solves the problem short term. Slashes are definitely a challenge frequently and its because they are a bit "special" especially as they sometimes need to be reversed for Linux. I suspect someone else has a much more slid explanation of why this might be happening though.
bubblebeb
  • February 9, 2018
Thanks Dave. I hadnt thought of that. Good short term fix.
Cheers
I tend not to use string transformers as I use python callers
HomeTeamFP = feature.getAttribute('HomeTeamFP')
DateFrom= feature.getAttribute('DateFrom')
DateTo= feature.getAttribute('DateTo')
#or if parameter
Name = FME_MacroValues['Name']
fullstring = '%SendKeys% "E:\FME\Development Work\TimesheetAnalysis\Output\{}\{} {} to {}{{ENTER}}"'.format(HomeTeamFP,Name,DateFrom,DateFrom)
feature.setAttribute('BatFile',fullstring)
could in fact write the bat files in python too
