SQLExecutor on MS SQL Server 2008 R2
francis_m
Forum|alt.badge.img+7
HI,
I need to make some simple sql query (like select COUNT(*)) on ArcSDE Table stored on a MS SQL server.
When I use the SQLExecutor, I can't connect to my DB.  How to connect.
I can read with a reader, I can write with a writer, but I need to perform some simple SQL query.
How to do this.
Server ?
Database ?
Do I have to create an OLDB connection on my windows OS ?
Thanks!
francis_m
  • May 14, 2014
See the error FME return
MS SQL Server Reader: Connection failed.  Connection string `Provider=SQLOLEDB;Data Source=Q1541BE;Initial Catalog=gs0599_i5;User ID=[MY_USER];Password=[MY PASSWORD]'. Provider error `(-2147467259) [DBNETLIB][ConnectionOpen (Connect()).]Ce serveur SQL n'existe pas ou son accès est refusé.'
Failed to open reader
what are the (working) connection parameters you're using to connect with SDE? And which parameters have you tried for the MS SQL Server reader?
David
francis_m
  • May 15, 2014
For a GEODATABASE_SDE reader / writer  I work with those parameters :
Server : s.o. (mean nothing but have to write something)
Username : my_user
Password : my_password
Instance Name : sde:sqlserver:q1541VIP,1456
Database : gs0599_i5
If I want to use SQLExecutor I need those parameters :
The value entered does not work...
Format : Microsoft SQL Server Non-spatial
Dataset : gs0599_i5
Server : q1541VIP,1456
Username : my_user
when I look at the error message that you posted above and compare it with what you posted just now, I see a discrepancy between the server names:
Log server name: Q1541BE
SQLExecutor server: q1541VIP
Could this be the cause?
David
francis_m
  • May 15, 2014
Hi!
Yes, thats depends on where I run my FME.  I need to connect BE (for Backend) on another machine, but I need to use VIP on my computer, but it's the same.
