SQL Executor; is it possible to output 2 or more geometry columns in one go?
  • September 23, 2014
  • 5 views
gio
Forum|alt.badge.img+15
Hi all,
I was wondering. If abovementioned was possibel.
I tried of course.
But it seems to only output the last in the select section.
I now use 2( or more)  identical Executors with different geometry columns.
I don't mean writing geometry to wkt or wkb attribute and then use geometryextraction after the executor.
I could but i don't want to do that.
Is there any way to?
gio
..possible
gio
..just grammar correction.
In case you thought i found out wether or not it is possible..
