Spatial Relate based on percent overlap
  • Nov 30, 2015 5:17 PM UTC
  • 5 replies
  • 120 views
Desired functionality scenario: criteria stating the minimal Requestor overlap percentage the Supplier needs to have. (e.g., Supplier overlaps at least 80% of Requestor, or else the record is <Rejected>).
I believe that adding this property to the SpatialRelator would add a lot of value and save a lot of complexity and time.
But for now, I would like to know in as much of a step-by-step fashion as possible, how to achieve this functionality, which I believe could be accomplished more elegantly with a SpatialRelator upgrade.
Feel free to chime in if you also support this functionality.
gio
Forum|alt.badge.img+15
  • Nov 30, 2015 5:40 PM UTC
No need for tht.
You can use an AreoOnArea overlayer to test for relative overlaps.
It is not complicated to do so.
I don't think an upgrade is nescessary for that.
You need to use a AreOnArea overlayer.
First create a area attribute for inputstreams by ID and fme_feature_type (or create a feature_type attribute yourself). (if objects to be compared are from a transformer, you can name the transformer and then expose fme_feature_type)
Create a area attribute (for instance "original_area")
Then use AoA with a list attribute set.
After AoA you do a areacalculator named like "overlap_area".
Create a string using a stringconcatenator on the list ID.
Test on overlaps >1.
Then use a tester to test if some or more ID's are within this string (with the "IN" test).
Then calculate percentage of contributing ID's (
round(100*"overlap_area"/"original_area"))
Then test if it's 80% (or whatever precentage is required).
If it's just two different ID's things are easy.
If more then testing is more extensiv.
You can, after selection, aquire original area'by using a merger on the ID attribute. ( or rdissolve them on ID and feature_type)
  • Mar 27, 2020 8:06 PM UTC
No need for tht.
@gio Can you please elaborate on the "IN" test?
  • Mar 27, 2020 9:28 PM UTC
No need for tht.
I still see a many-to-one number of steps involved rather than an optional percent-overlap parameter.
However, I'm very appreciative for you showing how to get it done!
gio
  • Mar 28, 2020 12:24 PM UTC
@vasuki A IN (a,b,h)
search in concatenated list
gio
  • Mar 28, 2020 12:25 PM UTC
The overlay is core, even if you put process in a tcl or python caller.
