“Spatial filter” with more than one filter source,
  • September 27, 2014
  • 5 replies
  • 163 views
jamal
Forum|alt.badge.img+5
A workbench is developed to convert parcels from CAD to GIS. The workbench is supposed to convert the geometry of the parcel to polygon and then to stick “parcel number” and “block number” to their corresponding fields.
The layers of the CAD files are shown below:
The workbench:
The challenge now is how to stick:
1. “fme_text_string” of the “Parcels_Texts” to the field “ParcelNumber”
2. “fme_text_string” of the “Blocks_Texts” to the field “BlockNumber”
How the FME can distinguish the “fme_text_string” that is coming from two sources?
CAD file:
http://www.mediafire.com/download/t7c90lryr3xsv31/Parcels_Al_Samou_06.dwg
Workbench
http://www.mediafire.com/view/j1if5qyypio27u1/Parcels_CAD_To_GIS_06.fmw
Thank you
Best
Jamal
Best answer by takashi
Hi Jamal,
The SpatialFilter cannot relate two or more Filter features to a Candidate feature at the same time. Consider using a SpatialRelator instead.
Alternatively, using two SpatialFilters separately for each Filter feature type can also be a solution. Two SpatialFilters might be easier than one SpatialRelator.
Takashi
jamal
Hi Jamal,
Takashi
jamal
Many thanks Takashi for the help.
I used the “spatial filter” twice and the issue is resolved.
Best
Jamal
  • September 28, 2014
Good to hear the issue has been resolved.
Here is an example for SpatialRelator, FYI.
Workspace Example (https://drive.google.com/file/d/0B0ufVP2t0eApSk5uVC1CR1RXalU/edit?usp=sharing)
Good luck!
jamal
Many thanks Takashi for the prompt help. This is very useful
Best
Jamal
