Sorting happens mostly by one attribute across a set of features. I would like to sort multiple attribute values (all of type datetime) across one feature and pick out the most recent date (of that particular feature) and assign it to a new attribute. I can imagine a lot of complex Testers, but it seems so obvious to use sorting of some kind. Any suggestions?
Sort attribute values per feature
Best answer by takashi
Hi @pimververgmail, if the dates are sortable format values (e.g. yyyymmdd etc.), you can populate them into a list and then extract min / max values with the ListRangeExtractor.
In order to populate the multiple attribute values into a list attribute, the ListPopulator or the ListExpressionPopulator could be used if the attributes are named with some specific convention, otherwise the AttributeListPopulator from FME Hub could be used.
