Sleep in FME?
  • July 9, 2013
  • 166 views
Can you pause execution (sleep) in FME? I am using the HTTPFetcher to send an address to Google to get back geocoded XML and extracting lat and lng. I find that some of the lat lngs are blank; however, when I examine those that are blank and send  the url directly to Google through the browser, I always get back the correct XML.
I'm thinking that because the HTTP fetch is inconsistent in the time it takes, something gets overwritten. I also did geocoding with Google using Python, and put in a sleep for two seconds. A sleep in FME might help.
By the way, I used the Gisgraphy geocode service in FME and found that it gave incorrect results. That's why I'm using Google.
Thanks
fmelizard
Forum|alt.badge.img+22
  • July 9, 2013
Recently the decelerator transfomer was introduced, sound like something that might help.
  • July 9, 2013
I added the decelerator, slept for two seconds per feature, and got all of my lat / lngs.
Thanks!
fmelizard
  • July 9, 2013
Your welcome.
You can also try the GoogleGeocoder from the FME store, it might simplify your ws.
