Simplify fme_surface
  • Mar 1, 2024 9:49 AM UTC
  • 322 views
marta.podsiad
Forum|alt.badge.img+12
Hi, I am trying to simplify .stl file that is a fme_surface.
I am trying to get from this
to this
I have tried MeshSimpifier and Triangulator+MeshSimplifier but it failed
Best answer by takashi
Hi @marta.podsiad ,
Just an idea.
  1. GeometryPartExtractor (Geometry XQuery : This part Geometry Type = Mesh part) : Decompose the Mesh geometry into individual Mash parts (Faces).
  2. SurfaceDissolver : Dissove asjacent faces on the same plane into a single face.
  3. Aggregator : Aggregate resulting faces into a MultiSurface.
  4. GeometryCoercer : (Geometry Type : fme_composite_surface) : Transform the MultiSurface to a CompositeSurface.
  5. GeometryCoercer : (Geometry Type : fme_mesh) : Transform the CompositeSurface to a Mesh.
Hope this helps.
  • Mar 2, 2024 3:43 PM UTC
Hi @marta.podsiad ,
Just an idea.
Hope this helps.
marta.podsiad
hi @takashi
Thank you for your message. Unfortunately, mesh simplification went too far while I was following recommended approach.
