RGB
Hello people I need help! how to generate RGB from a Geotiff.
danilo_fme
Forum|alt.badge.img+42
  • January 2, 2018
Hi @marcelosouza25,
Do you want to get the values RGB from a geotiff file? If yes you can see this Question Extract RGB value from Raster
If not, could you share us your Workspace template ( .FMWT )?
Thanks,
Danilo
danilo_fme
  • January 3, 2018
Hi @marcelosouza25,
Did you have success?
Thanks,
Danilo
danilo_fme wrote:
Hi @marcelosouza25,
Thanks,
Danilo
Thank you very much in advanceI think I expressed myself wrong, I need to create an R1G2B3 color palette on the output.Thanks,
Marcelo
danilo_fme
  • January 5, 2018
Hi @marceloraizen25 ,
No Problem. There is a interesting document about Palette Manipulation Raster Palette Manipulations.
If you want to share your Workspace template ( .FMWT ).
Thanks,
Danilo
Thanks,
Danilo
Danilo,I'm very grateful, that's what I was looking for.I will insert into the stream then share the result.Sorry, my english is Brazilian, I'm translating a message in Google Translate.Thank you
Marcelo
danilo_fme
  • January 5, 2018
Marcelo
Hi @marceloraizen25
Great. I'm happy to help you. :)
Yes, share us your result.
Thanks,
Danilo
tDanilo, Good Night.Follow the Workspace template (.FMWT). I set an example of my need.Previous flow are interresante, but I could not apply.Thank you very much in advance.Marcelo exemplo-necessidade.jpg rgb.fmw
danilo_fme
  • January 8, 2018
Hi @marceloraizen25
, thanks your Workspace.
I'll show and the answer.
Thanks,
Danilo
  • January 9, 2018
Hi @marceloraizen25, I found your sample raster data has four bands. What is the rule to convert the values of four bands to R, G, B values?
If you know the rule (mathematical expressions or detailed specifications on the source raster, etc.), it's possible to convert the source raster to an RGB color image with some transformers. Otherwise, it would be hard to make desired color image.
