Reprojection from EPSG:3413 - NSIDC Polar/WGS 84 to 3575
  • January 6, 2014
  • 73 views
Cheers!
I'm having a hard time trying to reproject som Icedata from NSDIC using FME. The data is shifted a bit too far south as the following discussion thread also seems to end with:
https://groups.google.com/forum/#!msg/fmetalk/ekh0-juHPiM/8I5UqSzq0nIJ
I tried the same suggestions and so far seeing exactly the same issue as Karl did.
I really would appreciate any help on this matter in order to get my workspace done. Reprojection seems to be ok using Arc Toolbox BTW!
Regards Stian
jdh
Forum|alt.badge.img+41
  • July 24, 2017
I'm also trying to define a custom coordinate system for ESPG:3413.  My custom projection definition is:
COORDINATE_SYSTEM_DEF WGS_1984_NSIDC_Sea_Ice_Polar_Stereographic_North\
DESC_NM "NSIDC_Sea_Ice_Polar_Stereographic_North"\
PROJ PSTERO\
UNIT METER\
DT_NAME WGS84\
PARM1 70\
ORG_LNG -45\
ORG_LAT  90\
X_OFF  0.0\
     Y_OFF  0.0\
GROUP CUSTOM
but the data is offset 35-45 km to the North
daveatsafe
Forum|alt.badge.img+24
  • July 24, 2017
Hi @jdh,
Please try using the PSTEROSL projection in your coordinate system definition, leaving the other parameters the same, and let me know if the fixes the offset for you.
jdh
  • July 24, 2017
Hi @jdh,
It gives the same results as PSTERO.
I'm attaching the data. My eventual goal is to work with the corresponding rasters.
arcticdem-tile-index-rel5.zip
