Which way or what transformer gives most accurate results (coordinates), Reprojector or EsriReprojector?
Thank you.
Thank you.
Best answer by david_r
the answer is: it depends.
Have a look at this article on fmepedia for more info.
If accuracy is important to you, I highly recommend that you test with your own data before you commit to either solution.
David
No account yet? Create an account
