ReplaceRegEx with another regExp with Text Editor
  • Mar 27, 2018 1:12 PM UTC
  • 5 replies
  • 153 views
denizturan1985
Participant
Hello all,
I have two questions.
1- Is it possible to replace regex with a regex? For example, I want to add a dot after every numeric value before any letter.
 StringBeforeAfter 1
7 St7. Street21 Av1. Avenue
@ReplaceRegEx(@Value(POI_NEW_NAME),^\d\s\w,^\d\.s\w,))
Search: ^\d\s\w
Replace: ^\d\.\s\w
2- I have different variations which I need to manipulate. Is there any possibility to use different expressions in a text editor of an AttributeManager? I tried to use "|" symbol for this purpose but it didn't work.
@ReplaceRegEx(@Value(POI_NEW_NAME),^\d\s\w,^\d\.s\w,))|
@ReplaceRegEx(@Value(POI_NEW_NAME),\d$,$\d\.))
Sorry, if it's a duplicate question but I couldn't find a similar case.
Thank you
lars_de_vries
Forum|alt.badge.img+10
Is it correct to assume that the output of the first string should be '7. Street'?
  • Mar 27, 2018 1:23 PM UTC
Try the following in a StringReplacer:
Or using an expression:
@ReplaceRegEx(@Value(String),"^(\d+)\s","\1. ")
Remark how we're using double quotes around the regular expressions since they contain certain special characters.
It won't convert "St" to "Street" for you, however.
  • Mar 27, 2018 1:26 PM UTC
Generally speaking, I would recommend posting each question separately.
denizturan1985
Participant
I corrected it. thank you @lars_de_vries
lars_de_vries
If you want to nest expressions in the AttributeManager, you could use the example below:
@ReplaceRegEx(@ReplaceRegEx(@ReplaceRegEx(@Value(before),^(\d+),\1.),(St)$,\1reet),(Av)$,\1enue)
If you want to test different versions, you could use a Conditional Statement in the AttributeManager to test first and use a different ReplaceRegEx string depending on the test result.
