Removing Redundant 'stacked' Vertexes From Lines
  • Apr 27, 2023 1:40 AM UTC
  • 6 replies
  • 176 views
ecx
Forum|alt.badge.img+8
Hello,
See picture below for example, I wish to remove the green vertex while ensuring that the end point vertexes remain.
I need to remove these as they are treated as being stacked, which is causing major issues with my ESRI Utility Network Model.
These points are within < 0.001m of each other.
I have tried using a generalizer, which is not appropriate for this situation, as the lines become much too generalised. I wish to only remove these vertexes that are treated as being stacked upon each other.
I have also tried using the geometryValidator -> issue to detect: remove consecutive points without success.
What other ways can I remove these points? I have thought about creating a custom set of transformers that could do the job, i.e. Find all vertexes -> identify any vertexes that are connected to other Line st/end points or any devices (as I want to keep these) -> find vertexes that are within 0.001m of each other -> single match these -> output. Although with this custom method I have no clue how to re-feed in the vertexes into the lines to update them.
Any help would be appreciated.
Thanks
Best answer by ecx
I ended up doing this, which I think will do the job.
  • Apr 27, 2023 11:03 AM UTC
Did you look at the Generalizer? Note that there are some algorithms that are better suited for topologies than others, see the help section.
jdh
Forum|alt.badge.img+41
  • Apr 27, 2023 5:10 PM UTC
Are these vertexes within a line, or pseudonodes between two lines that should be joined?
In the former, a generalizer should work, in the latter, look at the LineCombiner.
ecx
  • Apr 27, 2023 10:59 PM UTC
My lines (which are water utility pipes) require all vertexes to remain in their exact position as they are often gps positioned, apart from specifically the 'stacked' vertexes which need to be removed. I've had a look at the generaliser and it seems to simplify the geometry too much.
I dont think its appropriate to this situation unless you can suggest a specific algorithm type to use which fits my requirements?
ecx
  • Apr 27, 2023 11:00 PM UTC
These are vertexes within the same line, can you suggest a algorithm to use with the generaliser that can solve for the specific issue of removing 'stacked' vertexes?
ecx
  • Apr 27, 2023 11:02 PM UTC
jdh
  • Apr 28, 2023 2:16 PM UTC
Either the douglas or the thin algorithms should work in your case if the generalization tolerance is small enough. In the case of douglas you can even set the tolerance to zero.
