Reading Mesh Model in OSGB v3.4
  • Oct 23, 2017 2:38 PM UTC
  • 62 views
Hi, I'm doing something with Mesh model in OSGB format. But I found that only the geometry can be read by FME. The texture is missing. Did anyone tried something like this and had a solution of this?
daveatsafe
Forum|alt.badge.img+24
  • Oct 25, 2017 5:51 PM UTC
Hi @ben_nion,
The OSGB reader has a setting that allows you to specify the folder containing external texture images. If not set, the reader assumes that external textures are in the same folder as the .osgb file.
Please try setting Parameters - Texture Folders to the texture image location in your reader, then trying your conversion again.
