Reading from XML
ingalla
Forum|alt.badge.img+10
I am trying to read XML data from the following URL, which is for the food standards data in the UK. Whatever method i use to read this data i just get errors. Can anyone tell me how to extract this data correctly...
https://ratings.food.gov.uk/OpenDataFiles/FHRS131en-GB.xml
david_r
  • June 9, 2021
When creating the reader, make sure to tell FME which elements (XML tag) should constitute a feature, e.g.
xmlelementstomatch
ingalla
  • June 9, 2021
Perfect, thank you - missing the obvious!!!
