quote in InlineQuerier
endest
I want to query records of table A where the value of X contain value of Y in table B:
select * from A,B where X LIKE '%Y%'
It output nothing, I think the problem is the quote make Y into a normal string.
How to solve this?
Thanks
Best answer by takashi
Characters within single quotes will be interpreted literally. I think this statement generates your intended result.
select * from A,B where X like '%'||Y||'%'
Takashi
  • July 16, 2015
Takashi
endest
  • July 16, 2015
Thank you, Takashi. It works.
I just find the search result of Knowledge Center is different from Communit Answers. I didn't find your last answer when I search with the toolbar of Knowledge Center.
