PythonCaller that replicates the Windows command of "Send to Compressed (zipped) folder"
nicholas
Forum|alt.badge.img+12
Hello all,
I am trying to build a PythonCaller that replicates the Windows command of “Send to Compressed (zipped) folder”
The goal is to prepare a fileGDB dataset for transfer by ftp by zipping it
I want to give the PythonCaller a filePath such as D:\2024\03\project\data.gdb
Which then creates a zip file D:\2024\03\project\data.gdb.zip (that is, the zip file is sitting in the same folder as the data.gdb)
And, when the end user opens the zip file they see the folder data.gdb which they can then extract
I am trying using this code
    def input(self, feature):
        import os, shutil
        folder = feature.getAttribute('folder')
        fileGDB = feature.getAttribute('fileGDB')
        zip_file = feature.getAttribute('zip_file')
        if os.path.exists(fileGDB):
            print('fileGDB exists')
            if os.path.exists(zip_file):
                os.remove(zip_file)
            else:
                print('zip file DOES NOT exist')
            shutil.make_archive(fileGDB, 'zip', folder)
        else:
            print('fileGDB DOES NOT exist')
        self.pyoutput(feature)
But! the zip file contains itself! Which is wrong
Best answer by nicholas
I think I have worked it out
First, setup some User Parameters, both text
workingFolder is the folder that contains the fileGDB
fileGDB is the name of the fileGDB (without the folder)
Then, use Attribute Creator to create attributes from the user parameters
working_folder is the workingFolder parameter
fileGDB_name is the fileGDB parameter
fileGDB_contents is $(fileGDB)\*
zipFile_name is $(fileGDB).zip
Finally the PythonCaller
        print('+++++++++++++++++')
        print('start zip fileGDB')
        import zipfile
        import glob
        import os
        my_working_folder = feature.getAttribute('working_folder')
        my_fileGDB_name = feature.getAttribute('fileGDB_name')
        my_fileGDB_contents = feature.getAttribute('fileGDB_contents')
        my_zipFile_name = feature.getAttribute('zipFile_name')
        os.chdir(my_working_folder)
        if os.path.exists(my_fileGDB_name):
            if os.path.exists(my_zipFile_name):
                print('deleting zip file')
                os.remove(my_zipFile_name)
            else:
            print('writing zip file')
            with zipfile.ZipFile(os.path.normpath(my_zipFile_name), 'w') as f:
                for file in glob.glob(my_fileGDB_contents):
                    f.write(file)
        else:
        print('end zip fileGDB')
nicholas
  • March 5, 2024
        import zipfile
        import glob
        import os
            else:
                    f.write(file)
        else:
  • March 5, 2024
I believe you can tell FME to write the FGDB directly to a zip file by appending “.zip” on the writer.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/zip_files_writing.htm
nicholas
  • March 5, 2024
Hi @david_r yes that is true, if you are creating the fileGDB from scratch.
In my case, I am modifying the records in an existing fileGDB. Then I want to prepare the fileGDB for transport.
nicholas
  • March 10, 2024
I have attempted to modify the records in an existing fileGDB that is zipped, and I cannot get that to work
