Problems with FME 2014
Hey there,
i just started working with FME 2014 Oracle Edition 64bit. So i came across some things/problems/possibly bugs i can't seem to find a solution nor any helpful information. I was wondering if any of you encountered similiar problems or have even have a solution at hand. Here they come:
1. When entering a custom transformer CREATED in FME 2014 the content of a FMEBinary geometry storing atrribute gets always altered to "1O¨ƒ [GS][EM]" (with the GS and EM being black symbols) and therefore is pretty useless. Transformers created in FME 2013 don't do this and still work fine in 2014.
2. With some features going into the same custom transformer i get the following error message: ParallelProcessing_FindMaxTriangle_Feature_in1390212354 Input Splitter: This FME edition does not recognize the `hjTA' function. Please ensure that the current platform supports this function, the function name is spelled correctly, and that you have installed all required plug-ins alternativley i also get: This FME edition does not recognize the `RiTA' function I can't figure out where these functions come from, what they are supposed to do or why it only happens with a specific set of features. Has anyone seen that before?
Thanks in advance already for any help, much appreciated!
Greetings from foggy Freising
Matze
Best answer by matze_r
Hey David,
thanks for the tip. Didn't find anything though.
Found solution now though:
Something must have been wrong with the custom transformer.
Simple trick for fixing it was to export it as a custom transformer and reimport it to workspace. Solved both problems. So i am guessing FME does some validation while doing ex- or importing to fix things like that.
  • January 22, 2014
I have not seens these types of errors before. Are you sure that they are not related to your specific workspace? You could try to open the .fmw-file in e.g. Notepad (it's a regular text file) and search for "RiTA".
In general, it is difficult to say something specific about these types of errors without analysing the workspace and custom transformers.
David
  • January 22, 2014
Hey David,
