path_modified_date and Directory and File Pathnames Reader
  • January 9, 2025
  • 59 views
vxn43
Forum|alt.badge.img+18
What is the best way to extract the path_modified_date, path_created_date, and path_accessed_date for files in a folder (these are shapefiles and zip file)? I ran the Directory and File Pathnames Reader, and it shows these attributes as missing. Is there a transformer I need to use after this Reader to extract this information?
Best answer by david_r
You need to specifically activate the appropriate setting in the reader for this:
The reason is that requesting this information from the file system can have a performance penalty on some systems, especially for a large number of files.
  • January 9, 2025
