Password protected zip files
itay
Forum|alt.badge.img+17
Does anybody know how to create a password protected (encrypted) zip file with FME?
Preferably not using the systemcaller (not that protected...)
Any pythonistas out there with a ready example? @takashi @david_r :)
Cheers,
Itay
Best answer by itay
As expected python + 7z + awesome colleague (thx poosterveen!) provided the solution as a shutdown script:
import subprocess
OutputZipFile = str(FME_MacroValues['OutputZipFile'])
DirectoryToZip = str(FME_MacroValues['DirectoryToZip'])
ZipPass = str(FME_MacroValues['ZipPass'])
subprocess.call([r"C:\Program Files\7-Zip\7z.exe",'a', OutputZipFile , DirectoryToZip ,'-mx9','-p'+ZipPass], stdin=None, stdout=None, stderr=None, shell=False)
erik_jan
  • January 25, 2017
I don't know any FME solution at this moment.
So, I would promote this to an idea.
I see the use, so I will vote for it.
itay
  • January 25, 2017
Thanks, didn't expect a FME solution, hence the hint for a python solution.
itay
  • January 25, 2017
import subprocess
itay
  • January 25, 2017
Done!
https://knowledge.safe.com/idea/39057/to-be-able-to-create-password-protected-zipfiles-w.html
erik_jan
  • January 25, 2017
jdh
Forum|alt.badge.img+28
  • January 25, 2017
import subprocess
How does this substantially differ from using the SystemCaller?
In both cases an external program (7-Zip) is called via it's command line.
