Padright an int value
  • February 24, 2015
  • 16 replies
  • 138 views
Hi, I have some troubles with the following expression in expression evaluator.
@FindString(@Value(_IDENT),R)  ?  @PadRight((@int(@TrimRight(@Value(_IDENT), [R,L]))+18),3,[L]) : @PadRight((@int(@TrimRight(@Value(_IDENT),[R, L]))+18),3,[R])
I test if an attribute contains the letter R,
if yes, remove letters L|R, add 18, then add the letter L to the end
else , remove all letters L|R, add 18, then add the letter R to the end
Problem is, all i get is the calucated value and no final alpha character.
What is wrong with my syntax?
Thanks.
  • February 24, 2015
The ExpressionEvaluator is designed for evaluating a math expression, it may not work for string operations.
Consider using the AttributeCreator with Conditional Value setting.
Note:
@FindString function returns -1, if the target string doesn't contain specified string. If you intend to determine whether the string contains "R", the test clause should be:
0 <= @FindString(@Value(_IDENT),R)
And it's not necessary to quote arguments by [].
@TrimRight(@Value(_IDENT),RL)
@PadRight(<a string>,3,L)
String Functions (http://docs.safe.com/fme/html/FME_Transformers/FME_Transformers.htm#transformer_parameters/StringFunctions.htm)
Takashi
  • February 24, 2015
Personally I'm of the view that the "simplest" solution is usually the best. While it can probably all be done with a single very-complex expression, doing this makes it less maintainable. When you (or a colleague) next come to it you'll have to decipher what's going on within it.
Instead, I'd do it with transformers. A combination of the following should do it:
- Tester
- AttributeTrimmer
- StringConcatenator
- StringFormatter
Cheers,
Jonathan
gio
Forum|alt.badge.img+15
  • February 24, 2015
It also functions as bolean Takashi, try it out.
Bu the expression is incorrect. The @int needs a float as input, and is illogically used. Remove it.
Also the 3 suggest you only want 3 characters returned??? This should be ofcourse Original stringlength +1.
This works in the Expressionevaluator.:
@Evaluate(@Evaluate(@FindString(@Value(tst),R,0,T))?"@PadRight(@TrimRight(@Value(tst),[R,L])+18,@StringLength(@TrimRight(@Value(tst),[R,L])+18)+1,L)":"@PadRight(@TrimRight(@Value(tst),[R,L])+18,@StringLength(@TrimRight(@Value(tst),[R,L])+18)+1,R)")
The @Evaluate is mandatory to ..well have it evaluate
this results in:
gio
  • February 24, 2015
..should be Original stringlengt + 2 (for the number "18") +1 wich is same as
  • February 24, 2015
Hi Gio,
As an example value, 18R , I need to first add 18 to this, so i must remove letters, then perform the math 18+18=36, then apply the letter L. My final results needs to be 36R from original 18R.  The result I get from your expression is "17+18L" .
My explanation probably wasn't clear about that.
  • February 25, 2015
I agree with Jonathan. It's better to use existing transformers to make the workspace have higher understandability and maintainability, unless there is a special reason or the purpose is to learn more about FME functions.
If there were a reason for doing that within one transformer, I would use an AttributeCreator with Conditional Value setting, like this.
  • February 25, 2015
Based on the transformers suggested, I made it work. Although I did use a lot of transformers to do it.
  • February 25, 2015
Thanks Takashi for your help. Your answer was most helpful. Just a small modification
@Evaluate(@int(@TrimRight(@Value(_IDENT),R))+18)L
I have to include @int because occasionally the _IDENT has a value 08 for example, the zero infront causes errors.
I guess for the amount of time spent figuring this out, I did the alternative method in a fraction of the time. But its nice to have a single transformer solution.
  • February 25, 2015
Possibly these 3 transformers do that.
Modify appropriately the math expresion and the replacement character for 'C' according to your actual requirement.
StringSearcher
AttributeCreator
StringConcatenator
  • February 25, 2015
correction for the AttributeCreator setting.
  • February 25, 2015
In FME 2014 or earlier, there are cases where digits starting with '0' will be interpreted as an octal number in a math expression.  '08' and '09', for example, are invalid as octal number representation. Probably that's the reason for the error.
In FME 2015, digits always will be interpreted as a decimal number.
If you are using FME 2014, consider trimming leading '0's before calculation.
  • February 25, 2015
Sorry, correction again.
  • February 25, 2015
Thanks once again Takashi. That conditional value is quite convenient plus the regex. For my workflow I have to split them up to do the feature merge, but the process is overall much better to modify in the future I think.
  • February 25, 2015
Yes. The "Conditional Value" could reduce the number of transformers drastically in some cases, without using advanced function such as FME String Functions. I frequently use it.
It has been introduced in FME 2013 SP1. FYI.
FME 2013-SP1: Conditional Processing in FME (http://blog.safe.com/2013/03/fmeevangelist113/)
gio
  • February 25, 2015
I understand now, the IDENT format is integer plus a letter. Thats why u used a @INT().
I just surmised you were talking about a arbitrary string of arbitrary length.
I always prefer single transformer over a bunch of cumbersome transformers.
I only use conditional attribute creator for low count attributes (lik 2 or max 3) and then only sometimes, when im in a hurry.
I totaly disagree on  using existing transformers (note the plural..;0) in favor of the power of tcl.
"Time figuring it out" is a matter of experience and savvy.
gio
  • February 25, 2015
In that case the expression should be:
@Evaluate(@Evaluate(@FindString(@Value(tst),R))==-1?"@PadRight(@Evaluate(@Evaluate(@int(@TrimRight(@Value(tst),[R,L])))+18),3,L)":"@PadRight(@Evaluate(@Evaluate(@int(@TrimRight(@Value(tst),[R,L])))+18),3,R)")
resullts in
0 18R  36R
0 18L  36L
..i concede.. with that amount of @Evaluate() calls..6x .one might reconsider torturing oneself..
better do it in a tcl caller instead.. ;)
Im testing fme package..
and look wt# safe did!
fme_expression_warnings{0}.message (string): Failed to evaluate numeric expression '@real64(36L)'.  Result is set to null.
The result is correct as is the expressionstring and it gets processed as ususal, but it insists to intepret it as a number...?!??@#?? That is so lame!
