Overlapping polygons and latest date filter.
  • Nov 10, 2017 9:04 PM UTC
  • 88 views
I have a dataset of state pesticide permit polygons. Each polygon is identified by a permit number and site id plus there are attributes for effective date and expiration date. In many cases the polygons overlap in one of three ways:
  • 1. Edge overlaps where imprecise drawing causes overlaps.
  • 2. Polygons are designed to represent the same area. Sometimes these are drawn slightly differently so they are not exact matches
  • 3. The same area is divided into different numbers of polygons at different times.
What I need to do is take overlap cases 2 & 3 and keep the overlapping polygon with the most recent effective date.
Forum|alt.badge.img+63
The AreaOnAreaOverlayer can do the overlaying for you, if you set it to generate a list and then use a ListSorter to sort that list on the effective date you can use a ListIndexer to grab the attributes of the most recent element as the attributes of the resulting feature.
If you're concerned about the slightly different boundaries you could try using a Snapper before the overlaying to try and clean it up a little bit.
