Once I've created a Grid, is there a simple way to name each grid cell A1, A2, A3... D7, D8 etc?
  • April 28, 2016
Hi
If you created the grid using the Tiler, you can use the _row and _column attributes as the basis for this.
David
gio
Forum|alt.badge.img+15
  • April 28, 2016
use rownumber and charactercode extractor and charactercodereplacer.
Concatenate with columnnumber.
with start _row = 1 equivalent with A. etc.
CharacterCodeReplacer((CharacterCodeExtractor(A)-1) + _row)@Value(
_column)
or something like that..
