Merging geometries on different features
My SQL query returns multiple geometries from oracle. I need to use merge all geometries and return result in same feature.
 So when i use it in SQLExecutor, it creates different features with one geom. How can i merge geometries from all out features and return only one feature?
fmelizard
Forum|alt.badge.img+17
  • June 22, 2013
You can use the aggregator to create multiple aggregates based on a selection of your choice by using the group by  parameter, or a single aggregte by leaving the parameter empty.
Itay
  • June 24, 2013
Thank You. It works !! :)
