Merging features into a single textline
  • November 28, 2018
  • 6 replies
  • 306 views
Hi I have lots of features that have a datetime and some attributes, I need to group all the ones that happen in the same day on a single line. I need attributes A, B, C from the earliest item that day then I need to add attributes B and C from the other occurrences that day to the same text line.
I have split the date time up so I can see the year day month and time as separate attributes if needed.
If I have 4 attributes in a day then I would want them all grouped up into the same output text line exept the type needs tom come from the attribute with the earliest time
type(A) datetime(B) height(C)
90 2001-01-01T02:24:00 10
91 2001-01-01T08:28:00 15
90 2001-01-01T12:40:00 9
91 2001-01-01T23:24:00 14
90 2001-02-01T02:24:00 8
91 2001-02-01T08:28:00 16
90 2001-02-01T12:40:00 9
91 2001-02-01T23:24:00 12
so for the data above the 2 strings I'm trying to create would be
90 2001-01-01T02:24:00 10 2001-01-01T08:28:00 15 2001-01-01T12:40:00 9 2001-01-01T23:24:00 14
90 2001-02-01T02:24:00 8 2001-02-01T08:28:00 16 2001-02-01T12:40:00 9 2001-02-01T23:24:00 12
I think the feature merger might work but Im unsure how to split them into requestors and suppliers, the earliest item from each day needs to be the requestor and the rest the suppliers.
I'm sure I'm missing something obvious as this doesn't seeem too tricky, any help much appreciated.
Hoping there is a transformer way of doing this before I fall back to writing something in python.
Best answer by takashi
Alternatively, the Attributes to Concatenate option parameter in the Aggregator could also be used effectively.
Forum|alt.badge.img+49
I'm converting the datetime to an FME Date (e.g. 20010101), then sample based on those values, first occurence gets split off, all the others get a list built out of them. Concatenate the datetime and heights in that list into a new attribute, Featuremerge back to the first one and that's it.
csv22none.fmwt
Hope this helps.
Forum|alt.badge.img+31
  • November 28, 2018
Take a look at the aggregator
single_textline.fmwt
Forum|alt.badge.img+23
  • November 29, 2018
  • November 29, 2018
thanks Takashi, I went for this answer in the end as combining the time height and concatonating in the aggregator made things a bit simpler when generating my final output string.
  • November 29, 2018
Aggregator! thats the thing I was missing, I knew there was something I had used before, great answer thanks, but went with Takashi's one in the end, seemed the most elegant
  • November 29, 2018
csv22none.fmwt
Hope this helps.
thanks for the answer, I didnt use this method in the end but it was helpful, I havent used the sampler before, didnt know it existed but I have now made use of it now elswhere in the project thanks to you highlighting it
