Merge DWGs to 1DWG and put all objects to one new layer named as the original filename
  • Nov 13, 2017 3:30 PM UTC
  • 11 replies
  • 650 views
I have 1000 dwg that has text and lines on 2 layer, i want to merge them all in one dwg and the final dwg should have as layer names all the filename and all the objects (text,lines) should be in only one layer which is the filename the come from.
e.g t1.dwg, t2.dwg... -> merge.dwg (with two layer t1,t2...) every object from t1.dwg should be inside t1 layer in the merged dwg, same with the object from t2.dwg should be all inside t2 layer on the merged dwg, and so one for all the dwgs used as input.
danilo_fme
Forum|alt.badge.img+58
  • Nov 13, 2017 4:59 PM UTC
Hi @shefqetlulja,
I created a example to read a Folder ( files: file1 and file 2 ).
Steps:
1) Generate Workspace:
2) Expose the format attribute fme_basename on Reader option:
3) On Writer: Feature Type -> Layer Name = fme_basename
Thanks,
Danilo
Hi @shefqetlulja,
Steps:
Thanks,
Danilo
It says that Layer " '004016B' is not defined " which 004016b is the name of one of the dwg file 004016b.dwg
danilo_fme
  • Nov 13, 2017 6:15 PM UTC
Could you share the lof file?
Here it is
error.txt
danilo_fme
  • Nov 13, 2017 6:23 PM UTC
Thanks for the log file @shefqetlulja.
Could you share the Workspace?
Here it is
acad2acad.fmw
here you have the datasets too
004016b.dwg004016c.dwg004016d.dwg
danilo_fme
  • Nov 13, 2017 6:53 PM UTC
Please, try this Workspace .
workspace-dwg-edit.fmw
Yes, it work. what was the problem?
danilo_fme
  • Nov 14, 2017 1:00 AM UTC
I am happy that its works :) the problem was in Writer configurated by Dynamic.
Thanks
Danilo
Thanks
Danilo
Do you have any idea how can i split dwg every 300 or any other value, i dont want that my final dwg files has 19000 layers.
