Loss of attribute value Aggregator
In the same workspace, I have 2 "lines" of attributes.
I have to test an attribute value in line 1 to pass an attribute value of the line 2.
I tried with an Aggregator, but all the attribute values are gone just after the Aggregator.
Maybe it's just for geographical data.
Is there another way?
Or is it just my parameters in the Aggregator not right?
Best answer by slerendu
Unfortunaltely, I didn't manage to solve my problem.
A colleague of mine solved it with a FeatureMerger instead.
  • July 18, 2016
Hi @slerendu, how have you set the 'Accumulation Mode' parameter? ('Keep Input Attributes' in older versions)
  • July 18, 2016
Keep input Attributes : set to Yes
  • July 18, 2016
With your setting, the input attributes have to be propagated to the resulting aggregate feature. Can you show us your workflow and the parameters setting for the Aggregator?
  • July 18, 2016
On the left, you have the 2 lines going into the Aggregator. On the right, the Aggregator parameters.
  • July 18, 2016
hmm, I believe that the Aggregator should keep the input attributes, with your setting. Do the input two features actually have the attributes? The attributes don't appear on FME Data Inspector?
  • July 18, 2016
I didn't check the value from each Tranformer.
I lost the value in an early custom Tranformer.
Sorry fo the disturbance.
Thanks for your time :-)
  • July 21, 2016
peter100
  • August 4, 2023
I have a similar issue. After using Aggregator the result is one row only. The other 100 rows are no longer there. Is there an workaround to keep the other 100 rows?
peter100
  • August 4, 2023
I am using FME 2021.1.0.1.
Forum|alt.badge.img+32
  • August 4, 2023
I suggest starting a new question with the problem you are having and what you are trying to achieve. Include data if possible
peter100
  • August 7, 2023
I have a BulkAttributeRenamer in front of Aggregator. There I set the modus origin attributes keeping. After all works fine. Thanks for your help!
