Keeping highest date
joe.fme
Forum|alt.badge.img+4
Hi all,
I'm trying to keep the highest date in a range, and each of these has the same reference number. For example - "Reference Number 1 has 8 dates and we need to keep the highest date for Reference 1", but repeat a few thousand times.
I've had a method which worked before using Adjacent Attributes and sorting, but it doesn't seem to be working here. The dates are input in the %Y%m%d format (ie. 20120301) which I had hoped would make sorting easier.
I didn't know, after a long search and trying methods out, if anyone had any pointers on how to achieve this highest date business?
Thank you
nielsgerrits
Forum|alt.badge.img+54
StatisticsCalculator, group by Reference Number, Analyze date field (%y%m%d), Maximum Attribute is highest date. Complete outputport.
It should also work in the Excel way, with sorting and adjacent attributes. This is probably a less memory intense solution. But the StatisticCalculator is easier to configure.
Forum|alt.badge.img+32
  • January 13, 2021
Sorting in reverse order and then a duplicate filter should work here. The duplicate filter will output the feature with the highest date for each reference number from the unique port
joe.fme
  • January 14, 2021
Edit - just seen it in the "Complete" output port. Ignore my below comment, I'm a numpty!
Hi niels,
I've tried this approach but the correct answers come out of the "Summary" port - and only have the 2 fields, leaving the others out of the output (as shown). Is there something I'm missing?
To make things more complex the dates I've been given have only 1 of them with data in, which means the output is now incomplete - but that's for another time lol
