JSONTemplater single element arrays
  • November 3, 2021
  • 25 views
jdh
Forum|alt.badge.img+28
I'm using the JSONTemplater and have an attribute list.
 My (sub) template is
"id": fme:get-attribute("sumo_id"),
 "crosswalks": fme:get-list-attribute("_list{}.poly_id")
Which works fine if i have multiple list elements,  but becomes a string if I only have one.
    "id": "390335938",
    "crosswalks": ["225790", "2833648", "15808"]
    "id": "126630292",
    "crosswalks": "1243410"
when I'm looking for
    "id": "390335938",
    "id": "126630292",
    "crosswalks": ["1243410"]
Is there anyway to force the JSONTemplater to keep the array, or baring that what is the best way to post process the templater results?
Best answer by daveatsafe
Hi @jdh​,
If you enclose the fme:get-list_attribute function in square braces, it will force the array creation for lists with only one entry.
 "crosswalks": [fme:get-list-attribute("_list{}.poly_id")]
daveatsafe
Forum|alt.badge.img+19
  • November 3, 2021
Hi @jdh​,
