JSONTemplater does not set double quotes for number values
  • Oct 31, 2023 2:11 PM UTC
  • 121 views
tschoppenhof
Forum|alt.badge.img+7
My configuration in the JSONTemplater looks like this:
  "type": "Feature",
  "geometry": {
    "type": "Point",
    "coordinates": [
      fme:get-attribute("X"),
      fme:get-attribute("Y")
  "properties": {
  "33064" : fme:get-attribute("33064"),
  "33085" : fme:get-attribute("33085"),
  "33103" : fme:get-attribute("33103")
As result I get:
{ "type" : "Feature", "geometry" : { "type" : "Point", "coordinates" : [ 7.61438690276304, 47.5603635244644 ] }, "properties" : { "33064" : "", "33085" : 94328460, "33103" : "2. von B Spezmast Nr.55" } }
The number is not set in double quotes which results in error when I use the json string. Any ideas what could be the reason.
Best answer by takashi
Hi @tschoppenhof​ ,
You can cast a numeric value to a string value with the "xs:string" function.
Try this.
"33085" : xs:string(fme:get-attribute("33085")),
  • Oct 31, 2023 3:21 PM UTC
Hi @tschoppenhof​ ,
Try this.
tschoppenhof
  • Oct 31, 2023 3:34 PM UTC
Thanks takahshi, this works fine.
Hi @tschoppenhof​ ,
Try this.
This was helpful to guide me to all different XQuery functions, needed the xs:double.
For several other functions look at the w3 documentation
XPath and XQuery Functions and Operators 3.0 (w3.org)
