Iterate thru many oracle databases and get some data. How?
  • Mar 6, 2018 3:12 PM UTC
  • 5 replies
  • 65 views
Hi all,
I have ~50 oracle DBs. Each of them has instance name and the tnsnames.ora file is set up on the local machine. There is one same table in each of these DBs that I want to do a simple count on.
What is the best way to iterate thru all these DBs without the need to set up 50 or so readers?
Any input will be appreciated.
erik_jan
Forum|alt.badge.img+26
  • Mar 6, 2018 3:54 PM UTC
Create a csv file (or similar) with the database credentials.
Then create a workspace to read the table for one of the databases (and output to a file or whatever you need). Publish username, password and service name.
Crate a runner workspace, reading the csv file and pass the credentials to a WorkspaceRunner transformer that runs the workspace reading the data.
The runner workspace loops through the databases and executes the "count" per database.
  • Mar 6, 2018 4:06 PM UTC
Hi
Thanks for that. I am not sure I understand it completely. Could you elaborate more. What transformers do I need?
erik_jan
  • Mar 6, 2018 5:49 PM UTC
Hi
csv reader in runner workspace followed by a WorkspaceRunner transformer.
Database reader in second workspace for reading the table followed by StatisticsCalculator if you just want a count and a Text writer to output the count for the table.
  • Mar 8, 2018 10:30 AM UTC
I am a bit stuck still;
I created master WS (WS1) that has a csv reader. This gives me the service names of the DBs.
I connected to it a workspace runner transformer which runs WS2. In WS2 I have a published parameter for the service name (SID). Also I have a sql executor which uses the published SID as service name. And I just use a sql statement to count how many rows there are in a table.
How do I pass the service name from WS1 to the WS2?
jelle
Forum|alt.badge.img+23
  • Mar 8, 2018 2:07 PM UTC
the WorkspaceRunner will create automatically the possibility to fill in an attribute value for each parameter. Select your SID attribute that you read from your CSV writer. In the example below, I pass the Windows Path coming from the PATH reader. Should be similar for you
