InLineQuerier: Is it possible to Use an inbound Field as the WHERE Clause? Possible syntax error.
  • September 22, 2017
  • 7 views
Hi Folks,
I have successfully done a Cross Join In one InlineQuerier where the contents of a field called Query_Filter - is the WHERE Statement I want to apply in another InlineQuerier. I can get the statement to work fine when I paste it in to the second querier - EG
Select * FROM "Detected" WHERE (ChemCode ='7440-38-2' AND Concentration > 160 )
However when I Write SELECT * FROM "Detected" WHERE Query_Filter It doesnt work.
(Query_Filter just containing the text string above.)
Im missing something.
Any thoughts ?
Maybe try the following:
SELECT * FROM "Detected" WHERE @Value(Query_Filter)
Hi @pilgrimjake, I think your second query is equivalent to this one if the Query_Filter stores the text string "(ChemCode ='7440-38-2' AND Concentration > 160 )".
SELECT * FROM "Detected" WHERE '(ChemCode =''7440-38-2'' AND Concentration > 160 )'
A string literal won't be evaluated as an expression when the query is executing, so this query would not work as expected.
Also, the @Value function seems not to be available in a query for the InilineQuerier.
Probably you will have to think of another approach depending on the requirement.
