How to validate if number is pair or odd?
  • February 18, 2019
  • 144 views
mr_fme
Forum|alt.badge.img+8
I need to validade if the sum of the numbers is pair or odd.
How to make this?
lau
Forum|alt.badge.img+3
  • February 18, 2019
You can use a Tester with this test:
@Value(_your_number)%2 = 0:
Passed: even numbers
Failed: odd numbers
  • November 12, 2021
use this syntax with version 2021.1 : @fmod(@Value(_your_number),2)
