how to use regex to capture string and create attribute
I am trying to find a string with regex and put it in an attribute. I have used the stringReplacer, but this means I would have to search for what I don't want to capture and replace it with nothing so that what is left is the string I want to capture.
It seems as though capture-groups do not capture strings for subsequent use in fme.
Forum|alt.badge.img+32
  • March 10, 2020
Try the string searcher instead
  • March 10, 2020
Also, you need to specify a list name for the regex capture groups, otherwise you won't find them in the output:
