how to upload a draw polygon using third party tool to fme server
  • December 30, 2013
  • 9 replies
  • 11 views
Dear All ,
How to pass a geometry draw using geocortex to FME server . We have esri geometry draw by a user and we need to pass it to fme server .
thanks ,
Best answer by david_r
seems like there might be a bug in the GeometryReplacer that prevents it from reading the geometry string directly from a published parameter.
Use a ParameterFetcher first to put the WKT into a regular attribute. That worked for me (FME 2013)
David
  • December 30, 2013
one solution could be to convert pass the geometry as either WKT or WKB. You can then convert it back in your workspace using the GeometryReplacer.
David
Thanks David , but how to pass this WKT to geometry replace , do I need to use creator , what will be the input from the user
Thanks , it works great
Hi All,
I used David method to get the geometry as WKT but when I check it using shape file as an output or inspecter I did not see the geometry , May I know what might be the reason
  • December 31, 2013
can you tell us how you implemented it? My idea was something like this:
David
HI David ,
I am using the same method that you explained but when I passed the below wKT as input I am not seeing the polygon on shape file or inspector . do we need to add any other transfermer
POLYGON ((55.723644024000066 24.237742129000083, 55.723659275000045 24.236346177000087, 55.725385866000067 24.23637092000007, 55.725414275000048 24.237711484000044, 55.723644024000066 24.237742129000083))
  • December 31, 2013
David
WOW David , awesome man , it works like a champ
  • December 31, 2013
Glad to hear it works.
For what it's worth, it seems like this bug has been resolved for FME 2014.
David
