How to thin an PointCloud where the Points are lined up
  • July 27, 2017
  • 64 views
Hey,
another problem ocurret with the PointCloud file, in this case all Points are lined up in the orignal File like rectangles. If i do the "normal" thin setup i became only slope lines. I need mixed up points all over the area. Is it possible to do ist with FME. You can see the problem an the Setup on the screenshots.
  • July 27, 2017
Hey,
Forum|alt.badge.img+63
The PointCloudThinner won't do this, you could try using a SurfaceModeler taking your point cloud as input and then setting the output DEM X and Y spacing to whatever you want. The DEMPoints output has the re-interpreted points.
lars_de_vries
Forum|alt.badge.img+10
Hi @florena1,
have you tried to use a different setting? Using the 'Every Nth point (Interval)' with a different setting could bring a different result. The setting you used spreads it evenly, creating this pattern.
Otherwise you should perhaps keep more points at first?
