How to read Oracle Spatial geometry in between the flow?
I am able to read a Oracle Spatial geometry using FME "Oracle Spatial Object" reader. However when I am trying to read a SDO_GEOMTERY using SQL_Executor, I am not able to expose the geometry attribute. How do I read a SDO_GEOMTERY in FME in between the flow?
Regards,
Ananda
Best answer by david_r
you can use an SQLExecutor with something like
select sdo_util.to_wktgeometry(shape) as SHAPE_WKT
from myschema.mytable
where objectid = @Value(OBJECTID)
You can then expose SHAPE_WKT and use the GeometryReplacer to convert the text back into a proper geometry object (specify OGC Well-Known Text as encoding).
David
  • June 20, 2013
David
fmelizard
Forum|alt.badge.img+18
  • June 20, 2013
Optionally you can access the oracle features via a feature reader.
Itay
gio
Forum|alt.badge.img+15
  • June 21, 2013
Yeah, u need to explicitly select the geometry column in ur sql query to get it exposed.
Like David said.
syedh2993
Forum|alt.badge.img+5
  • October 30, 2024
I have similar scenario like in this thread.
I have a CSV file which has oracle geometry object in below format
Example:  MDSYS.SDO_GEOMETRY(3002,null,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,2,1),MDSYS.SDO_ORDINATE_ARRAY(123456.742,234567.714,0,789123.786,5432156.2392,0))
It is a Multiline geometry. Using Database Reader, FME automatically recognises the geometry. However, in CSV file it doesn’t.
Would really appreciate if anyone can help with below
  1. which transformer to use so that FME recognises the above geometry ?
  2. is there anyway to extract Lat Long for the above ?
Thanks,
Syed
saraatsafe
Forum|alt.badge.img+9
  • November 6, 2024
Hi @syedh2993
You can try using the Oracle Spatial Object Reader instead, and then using a VertexCreator to create points from your latitude and longitudinal information. I hope this helps point you in the right direction!
syedh2993
  • November 7, 2024
saraatsafe wrote:
Hi @syedh2993
Hi Sara,
Thanks for the response. I am not sure if I can use Oracle Spatial Object Reader in this scenario as my source data is CSV file and not Oracle database.
