How to Populate Values of a Published User Parameter of Type Choice Using Scripted Python Parameter
  • Jun 1, 2020 11:09 AM UTC
  • 92 views
Is it possible to populate Values of a publish user parameter of type choice at runtime using scripted Python parameter or using any other approach?
itsmatt
Forum|alt.badge.img+48
  • Jun 1, 2020 2:34 PM UTC
Not exactly as you've described, but you can use the choice from a 'choice' parameter in a scripted parameter to generate something else.
There is also the option to use Choice with an alias?
What is the use case?
itsmatt
  • Jun 1, 2020 2:35 PM UTC
Of course - if you are running FME from the command line or on FME Server via a web call then the is of course another way to populate published parameters.
Thanks @virtualcitymatt for your reply.
I'm using the Data Interoperability extension for ArcGIS, and want the user to select the target geodatabase version from a list as a parameter for the tool to run.
