How to insert a new key value pair into a JSON file, where the value is based upon an attribute
  • October 24, 2018
  • 5 replies
  • 223 views
friesewoudloper
I have a dataset with an attribute containing a JSON file for every feature. The dataset also has an attribute called frequency. I'd like to add the key frequency to the JSON file, with the value in the frequency attribute. I tried using the JSONUpdater transformer:
Update Type: Insert into Object
JSON path: json
Object/Array index: frequency
Value Type: Plain Text
Value: [the value of the frequency attribute]
The resulting JSON file has a key frequency with a string of length 0 as a value.
I also tried:
JSON path: json
Value Type: JSON/XQuery
Value: fme:get-attribute("frequency")
This time the result was a key frequency with a value of null.
How do I resolve this?
Best answer by jdh
The value type should be plain text, and the value should just point to the attribute.
The following works fine for me.
Just to verify, you are attaching the feature to both the Document and Update ports?
jdh
Forum|alt.badge.img+28
  • October 24, 2018
friesewoudloper
I hadn't connected the feature to the Update port. Connecting it however doesn't solve my problem. The processing time increases very much. But that isn't the biggest problem. For most of the features, the frequency key in the JSON file doesn't have the right value.
I have 217 features in my dataset. I think the frequency key in the JSON file is now updated 217 times *for every feature*. After running the workspace, all JSON files seem to have the same value for frequency, namely that of the frequency attribute in the last feature that was processed.
friesewoudloper
@jdh got me thinking: maybe I should use the 'Group Update Features By' parameter? I'll give it a try.
jdh
  • October 24, 2018
If you have multiple features and you want each feature to be treated individually, you need to set the group by, on a unique attribute for each feature.
friesewoudloper
You are right! It works fine now. Thank you!
