How to handle when there are different custom properties for each IFC?
bskim
Participant
HI.
Do I still have to manually input using the AttributeExposer transformer, like the answer to the question below?
https://community.safe.com/s/question/0D54Q000080hcshSAA/problem-ifc-reading-user-attributes
What should I do when a user-defined property exists for each IFC file in the way that the fmw file runs FME Application in the shell and operates?
please answer about my question.
Regards,
Bongsup Kim​
Best answer by daveatsafe
bskim wrote:
Hi @daveatsafe ,​
Thank you for the reply.
By the way, the question is whether there is a way to automatically feature caching when running in the shell, not through the workbench.
Best Regards,
Bongsup Kim
Hi @bskim​,
The attributes are always on the features - the AttributeExposer just shows them to you in Workbench. If you want to propagate the different property sets to the output feature when running in the shell, I recommend using the SchemaScanner transformer to generate a schema from the source features, then set the output writer to dynamic mode, using the schema feature to set the output schema.
Screen Shot 2023-07-11 at 10.31.15 AM
daveatsafe
Forum|alt.badge.img+19
Hi @bskim​,
You still need to use the AttributeExposer after extracting the IFC property sets with the GeometryPropertyExtractor, but newer versions of FME have made this much easier, using Feature Caching.
  • In Workbench, choose Run from the top menu, then ensure that Enable Feature Caching is highlighted.
  • Add a new AttributeExposer and connect it where desired, then run the workspace to populate the caches, ignoring the incomplete transformers warning.
  • Edit the AttributeExposer, then click the Import button at the bottom and choose From Feature Cache. A dialog will come up showing all the available attributes on the cached features. I generally choose Select All, then Import.
  • Click OK to save the AttributeExposer settings.
bskim
Participant
  • Participant
  • July 7, 2023
Hi @daveatsafe ,​
Best Regards,
Bongsup Kim
daveatsafe
bskim wrote:
Hi @daveatsafe ,​
Best Regards,
Bongsup Kim
Hi @bskim​,
bskim
Participant
  • Participant
  • July 13, 2023
Hi @daveatsafe
I don't understand the answer you gave to solve the problem.
May I ask for an answer based on the attached fmw?
Best Regards,
Bongsup Kim
daveatsafe
bskim wrote:
Hi @daveatsafe
Best Regards,
Bongsup Kim
Update workspace for dynamic output.
bskim
Participant
  • Participant
  • July 14, 2023
Hi @daveatsafe​
I remain deeply grateful for what you have done.​
​Best of luck for your future!
Best Regards,
Bongsup Kim
bskim
Participant
  • Participant
  • August 29, 2023
Hi @daveatsafe (Safer)​
There is a problem that material files are not created intermittently when converting IFC files to OBJ.
This happens about once or twice out of 10 attempts.
No exact reproduction pattern was found.
Best Regards,
Bongsup Kim
