How to handle an IFC Property missing when reading the IFC file
  • Jul 25, 2024 6:51 AM UTC
  • 205 views
bruno
Forum|alt.badge.img+3
Hello to all,
I have a problem with an IFC file where some IfcProperty are referenced by a propertySet but not defined. Then, I have a message like this : IFC: Could not find instance #245009 in the IFC file.
So, my question is to know if it is possible to say to FME to continue to read the file ?
Thank in advance
Best regards
Bruno
Best answer by donalmateer
Hi @bruno,
Thank you for the question!
I believe an easy fix to this issue could be to change your workspace parameters in the navigator window.
Workspace Parameters > Translation > Rejected Feature Handling.
Changing this parameter should allow the translation to continue.
I have also attached two similar community posts that may assist you:
How to handle when there are different custom properties for each IFC?
How to read custom IFC properties?
If you have further issues please reach out again and I can look into the issue further!
Thank you,
Donal.
donalmateer
Forum|alt.badge.img+13
  • Jul 29, 2024 9:31 PM UTC
Hi @bruno,
Thank you,
Donal.
bruno
  • Jul 30, 2024 6:19 AM UTC
Hi Donal,
Thank for your answer. Finally, I asked my colleague to correct the IFC model because there was a process that removed the property without removing the associated relationship. The IFC model was therefore not correct. But I keep your answer in mind which can be very practical ;-)
Best regards
Bruno
